artem 1) how to update the Hand controller one in order to keep it compliant with the mount
to update the hand controller, you need to attach / connect to AM5 and then with the new SKYATLAS APP
you can update not only the AM5 FW but also the Hand contrroller also, BUT! I did already check and there is no new update for the hand controller but only for AM5 FW Version 1.5.1
Hello @artem , I will try that. I have connected my mount to the phone through the skyatlas application. I go in the settings in order to connect the mount, that's OK. I could move the mount, set the FOV with my specific settings (camera & tube focal lenght).
I do not see the Home button
I do not see an interface with the version of the HC & the mount & update buttons. I have seen that it the old ASIMount version of last year. Here, I see nothing.
Perhaps, I have no see correctly. I will look further at my next connection.
Many thanks for your help, good sky
