Last night, I ran PHD2 for 15 minutes using your recommended settings. RA: AGR35, HYS30, MINMO.07. Same for DEC except MINMO .1 and AGR45, 500ms pulse for both. I also ran Guiding Assistant to check DEC backlash (980ms). I know these mounts don't have any, but I had to check it out while I was in there.
After a good run with PHD2, I plugged in the ASI Air Mini to see how it would do and to my surprise, it did very well. Awesome! Then, after maybe 15 minutes, guiding became unstable. Not too bad, total RMS around 1.5, but I figured it would sort itself out and I decided to go to bed. The next morning, I checked my phone and total RMS was around 3-4. Guide logs for the entire night were a mess.
Maybe the ASI Air is the culprit. It seems like it's struggling to produce a constant 1fps to keep up with corrections.
Tonight, I am running NINA and will post guide logs tomorrow night. So far, all is good.
On a side note, I have to say the whole NINA experience so far has been smooth. Plate solving is lightning fast and NINA's 3-star alignment actually works great with my L-Extreme filter in. I usually have to set my guide cam as the main camera because the Air has trouble plate solving with L-Extreme in.
