I checked in on the Am5 owners' group over on cloudy nights to see anyone has had issues with their mount.
A couple of suggestion were to check Pa, loose connections, mount stability etc... I should mention that my rig despite its current issues guides great at the equator and meridian intersection. I posted some pictures of my success last night over there before checking guide logs. ASI Air can be deceiving at glance when you're looking at guiding from the imaging screen because it only shows 50s timeline.
I just checked guide logs and noticed a couple of times last night RA and DEC were spiking around 7-9.
Something is loose, has to be. how can guiding be so good in the most difficult place to guide and go complete bonkers when pointed at something closer to the poles?
I had said earlier that the main camera was loose, and I was able to get 1/8th of a turn on it. Well...I found that the manual rotator was loose, and the main camera had pretty good amount of play in it. My guide camera sets on top of the main scope, and I think a little play in the main camera is probably causing some movement in the whole OTA.
LOL I'll give her a go tonight and see what happens.
Spikes I was seeing.
