Tech@ZWO @johnpd
What this means is that for the Comet database to update you will need a device that can access the Internet and the ASIAIR at the same time.
This can be done one of three ways:
With a device that allows you to connect to mobile data and a Wi-Fi network at the same time. So you would connect to the ASIAIR Wi-Fi, enable Mobile Data (if it had been disabled), launch the ASIAIR App, connect to the ASIAIR device, and it will update (possibly after going past the initial settings screen).
With a computer that is connected to a network with Internet access and the ASIAIR WiFi at the same time. This can be done, for example, with a computer connected via Ethernet cable to your home network, and then using the the same computer to connect to the ASIAIR Wi-Fi. Or you could being directly connected to the ASIAIR Plus/Pro via Ethernet cable and connect to your home network via Wi-Fi (possibly).
The computer will be running BlueStacks 5 in order to run the ASIAIR App (Windows 10 / Mac / possibly Linux) or using Windows Subsytem for Android (Windows 11).
- ASIAIR in station mode connected to your home WiFi. Use mobile/computer on same Wi-Fi network to connect to the ASIAIR. Just need to make sure your home network has Internet access.
