My rig has a choice of three cameras - a main camera (3,000mm focal length), a guide camera, and a wider-field "finder" camera.
At present I have to manually select the "finder" camera as the MAIN camera to do the polar alignment, and then GOTO and plate-solve. I then manually select the real "main" camera to start imaging at 3000mm.
Would it be possible to add pull-down menus to choose a specific camera for the plate solve function, and and a pull-down menu to choose a camera for the polar alignment, instead of always using the main camera, and have those settings remembered for the evening ?
