Tech@ZWO
I ordered the CAA right away.
However, currently with the ASIAIR it seems the Rotator can only be mounted one way as there is no reverse operation option in the settings looking at the youtube reviews.
I want to avoid the Filterwheel rotating and thus potentially be in a position where it hits the tripod or pier.
Also on some setups the rotator may not be able to be installed because of the notch hitting parts of the focuser/ large diameter Adapter. In this case a reverse mounting is also necessary.
I am using a pegasus rotator for years with SGPro in reverse mode and it works fine. As I keep my optical train always clean und leave it always assembled, I have no issues with the flats. Also keepting the filters farther away from the sensor reduces greatly the effect of dust.
Another important point that many ppl are not aware of is that there is less vignetting when the Filter is closer to the reducer/ corrector.
While this may seem counterintuitive, many corrected optical systems work with projecting the image on the sensor. At least this is what I read in some AP forums.
Let me know what you think.
Stephan
