Tech@ZWO
Thank you for your answer.
Yes the problem only occurs 30 minutes before to 30 minutes after meridian flip.
Plate solving then becomes an endless loop.
I have already tested this. I canceled the GoTo plate solving (GoTo Autocenter 10 sec exp) and went to preview, the plate solving there gets into an endless loop again.
I also took test shots in the preview with an exposure time of 10 seconds. The shots look good, as good as before the error starts. But I don’t save this test shots.
The crazy thing is that afterwards, when the object is well after south around 30 min, everything works perfectly again with the same settings.
