I tested Android version 2.2_0403 11.05 tonight. I was using AIR Plus 256 unit. Here's what happened.
Started normally, all devices found: AM5 mount, EAF, ASI585 osc camera, ASI220 mm camera, Edge 8, WO 200 and USB memory stick. PA to 33". Slewed to M81 and centered. Tried to "solve" and sinc; but, NO response. Repeatedly. Guiding calibrated to about .30 and started normally. Set Auto Run to 2 min for 45 exposures. Dithered each 10. Set eMMC as repository of images. Set refocus for 1 deg C change. Started AR. For 36 exposures, No issues; 2 dithers and 2 refocuses..
Then no 37 wouldn't transfer from camera to memmory for an abnormal of time, but did finally. 38 & 39 appeared normal. No 40 imaged but wouldn"t transfer. I waited 5 min about and shut it down... It was at the meridan.
Sorry for the long text.
Edit:: Although it didn't display that the images transferred; they were all there?????????
