First Light with new ASI585MC Pro.
Kevin_A what filter size and camera did you use on the Flame and Horsehead? Or maybe that was not part of your test.
The Horsehead was an archive from the past. 2" IDAS NBZ filter on a FSQ-85 with 1.01x flattener (457mm focal length). During that test, the Radian Ultra (company, OPT, is no more; OPT bought by Agena), out of my various narrowband filters, produced the most halo-free Alnitak. If memory serves (I need to go back to check the images), Optolong narrowband was the worse. Not a surprise.
So far, from last night, it appears that 49mm Tiffen (f/3.1) is the smallest aperture that I have which has no aperture vignetting (that circle with a bite taken off it) across an APS-C frame. 40.5mm filter (f/3.85) has aperture vignetting. So far, any filter that creates an aperture that is wider than f/3.1 appears to work fine. The 52mm that you have should be clean.
So, I went and ordered components to use a 46mm filter. 46mm Tiffen is out of stock at Amazon, so I ordered a K&F (even lower end than Tiffen) filter, which hopefully does not have retaining ring that is too tight. It should give somewhere around f/3.3. I will do a sweep once that arrives. We have a power outage here (car drove into a utility pole, apparently), so I have to wait until power is restored too, to do any more.
If 52mm is not too large an opening for you, you can start testing with it. I tend to prefer 2 f-stops (would be f/3.5 for the Samyang) down from wide open, but the Samyang 135/2.0 appears to be better than other lenses, so 1.5 f-stops down could be good enough -- especially for an APS-C frame.
- Edited
w7ay I will test in a few days as I have to wait for the 77-52 ring to arrive for my Rokinon and 2600.
I am also needing to test my 805mm without a reducer ( with WO M63 to M48 spacer adapter) on the ASI585mc pro at 60s and at HCG and to test my new Esprit 100ED with my 2600mc Pro.
Lots to do….
Kevin_A I am also needing to test my 805mm without a reducer
I have lots of other stuff I can do too. Trying to combine 2600MM and 2600MC in AstroPixelProcessor is one of them; others have done it, but Ihave never tried it.
BTW, forking the guide scope below the RST-135 RA axis does work, but is a little heavy and cumbersome, so I am back to the side by side dual saddle for the time being, which served me well since a few months into getting the first RST135.
But I have another project, which is to mount the RST-135 itself on a single fork. The polar alignment is done by the fork itself, so I am working on bearings and stuff like that right now. I am hoping for 1) better polar alignment, 2) no Meridian flip and 3) low height to mount the OTA. The main fork arm is a long 40-8080 extrusion to avoid flexure (angled from the ground at the same angle as my latitude, and on bearings. The forked guide scope should also work with this fork mount, and guiding through a meridian transit should be free from a flip too.
Kevin_A interesting
The right way to fork the guide scope below the RA axis is to do it from the mount itself, like Avalon M series and what SkyWatcher has shown for their strain wave mount. I.e., the "counterweight shaft" actually rotates with the declination axis. RST-135 counterweight shaft is fixed, and ZWO blindly copied it.
Unfortunately, there is a Cloudy Night posting from SkyWatcher (HQ in Taiwan) that their strain wave mount will not come out soon. Unlike ZWO, they seem to do testing of their products. You can tell us if their OTA is also tested more than the Askars and SharpStars.
Kevin_A test my new Esprit 100ED with my 2600mc Pro
Wow, that is some short dovetail plate on the Espirit. Time to visit ADM's web site, eh ? :-):-)
Good to see that you have some flatteners/reducers on it. APO does not mean a thing for astrophotography if the field is not flat, and a triplet will not by itself have flat field (as opposed to a Petzval, which can be designed for flat field). APO just means three wavelength rays converge at the same spots; for a refractor, they don't converge on a flat plane (as the poor SeeStar people, who fall for the APO nonsense in the ads, are finding out).
Kevin_A I will test in a few days as I have to wait for the 77-52 ring to arrive for my Rokinon and 2600.
I ordered the 46mm stuff last night and Amazon says they will deliver tonight. The power company also promises electricity will be restored by 4:15pm (it has been creeping slowly; I am just hoping before nightfall -- a neighbor saw them trucking a new utility pole, so some drunk or teenager must have ran into one :-)
In the meantime, this is the kluge I am using to measure:
The ruler is at the focal plane (44mm from the EOS flange), and the camera rail sits 250mm from the ruler. The camera rail is just a kludge of ARCA dovetails:
The kludge is sufficient to allow me to raise and lower the camera, and to shift it left and right to see the vignetting at different distances from the optical axis at the focal plane (that ruler).
Camera is a ASI294MM and lens is a Fujinon HF-16HA (low distortion Machine vision lens, 16mm focal length) that I have around; I use a longer focal length version of this lens as my solar finder, with a ASI290 mini.
- Edited
OK, here is a detailed, and more accurate measurement.
The measurement set up looks like this:
The Rokinon 135mm/T2.2 is at the far end, and we are looking at a Canon EOS flange. A ruler is placed at the focal plane of the lens (44mm from the lens flange).
At the near end, there is a ASI294MM camera with a Fujinon low distortion 16mm lens (HF-16HA). with a ring light around it (to illuminate the ruler).
The camera is mounted on ARCA dovetail plates (ring light not shown) to allow us to center the camera onto the optical axis of the lens.
This is what a centered aperture looks like from the Rokinon lens. Notice the red crosshair lines with the vertical line coinciding with the "60mm" marking on the ruler. The Rokinon lens has the lens hood mounted (not an issue, but I will mention it), and the T-stop set to 4.0 (close to f/4.0 on a non-cine lens).
The ASI294MM camera is now moved sideways in this next image, with the crosshair placed at 60mm + 22mm. The 22mm offset at the focal plane corresponds to a 44mm diagonal of a full framed camera.
Notice that the shape of the bright aperture remains the same 9-bladed iris, undistorted. There is no aperture vignetting, even at the corner of a full frame camera.
However, star images will show quite pronounced radial spikes (9 spikes + 9 more spikes flipped, for a total of 18 spikes).
The lens is next set to its full opening (T/2.2), and a circular aperture mask is placed in front of the lens. The mask is made up of a 77mm-55mm step-down ring, followed by a 55mm-37mm step-down, to create a composite 77mm-37mm step-down ring. A 37mm Tiffen UV filter, with its UV glass removed is place on the step-down ring, creating a clean circular aperture of 33.7mm, equivalent to an f/4.0 aperture of a 135mm lens.
Notice the aperture is completely round, instead of looking like a regular 9-sided polygon. This should produce stars that are void of radial diffraction spikes, at least for a star near the optical axis.
Next, we move the camera so that it is centered at the "70mm" mark on the ruler. A star that is 10mm away from the optical axis, will be seeing this following aperture:
Notice that the aperture is still completely circular, but simply displaced. The star will suffer from other lens aberrations, but it is no aperture vignetting.
We now place the crosshair at 14mm -- this corresponds to a star that is 14mm away from the optical axis on the focal plane, i.e., a star that is at a corner of a APS-C frame that has 28mm diagonal.
Notice that there is some slight non-circular irregularity on the left side of the circular disc.
A star at the corner of an APS-C frame will suffer from a slight (very slight) amount of aperture vignetting. This will create two notches in the PSF around a bright star, as discussed here:
https://www.cloudynights.com/topic/547028-anyone-know-what-causes-this-artifact-on-bright-stars/
We now move to the corner of a full frame camera with 44mm diagonals (i.e., 22mm away from the optical axis):
There is now severe aperture vignetting.
What this implies is that a 33.7mm circular mask that is placed just in from of the Rokinon lens will probably be usable for APS-C cameras, but bright stars towards the edges of a full frame camera will show the diffraction notches.
Interestingly, a larger mask will show less aperture vignetting! This is an aperture that is made from a Tiffen 55mm filter (with its glass removed), from the same 22mm away:
The Tiffen 52mm filter with the glass removed has a clear aperture of 49.7mm. Producing a f/2.8 aperture for the 135mm focal length.
The above appears to imply that for APS-C camera can at most be masked to an f/4.0 on this lens (and there may be a slight, perhaps not really visible except on the brightest stars, aperture vignetting at the far corners). But when masked to look like an f/2.7, the stars are void of aperture vignetting all the way to the corners of a full frame camera.
The next image is from a 46mm UV filter with the glass removed, producing an f/3.3. Offset of 22mm (corner of full frame camera), so it may be possible to mask the lens down to a smaller f/3.3, and not suffer aperture vignettng even on a full frame camera.
w7ay I have two ADM plates on back order to replace the utterly short stock one. I did 2 hours last night on my 115mm triplet sans flattener with the 585 and surprisingly the stars are quite round and I will post a pic later. It was just a test to see if my scope or flattener is introducing abberations… so far it looks like it may have been my flattener reducer at fault.
- Edited
Kevin_A so far it looks like it may have been my flattener reducer at fault.
Or the backfocus distance of the flattener? :-)
Speaking of backfocus, I just ordered a weird 17mm long adapter from PreciseParts so I could add a "prefilter" to my FSQ-85 train. Currently, with a 20mm thick filter drawer or filter wheel, I am left with less than 20mm for the FSQ flattener's backfocus. I can't add a second filter drawer. I'm planning some experiments since some chap on Cloudy Night some time ago mentioned that a UV/IR cut may help with haloing on narrowband OIII filters. I can't think of any technical reason why it should, but I am willing to try check it out by inserting an Astronomik L1 ahead of the filter drawer.
There simply aren't enough cloudless nights to perform these experiments! I definitely need to confirm the aperture vignetting numbers with real stars (bright star at corners of frame). I have added the 46mm filter to my table (see below). So far, the sweet spots appear to be 46mm filter, which makes the Rokinon into a "40mm astrograph" for full frame, and 55mm filter, that makes it a "50mm astrograph" if the other aberrations are under control at f/2.8 (just one f-stop from wide open). By the way, even the f/3.3 won't work with the original Antlia ALP-T (which is the filter that I have). Antlia has since put out an ALP-T that will work with faster f-numbers, but the Radian I have should be able to handle fast f-numbers.
w7ay Good to know!
I did manage a measly 2 hours last night with the 585 at HGC for 60s and it seemed ok! No flattener was ok too. It was really noisy due to no filters, full moon and just 120 x 60s subs but for posting online I can’t complain. The 115mm triplet has CA, but it seems less without the reducer/flattener.
I will have to see if I keep it or put it in the sell pile! Haha Here is a comparison of 2 hours at HGC vs 3 hours with reducer at Gain 198.
- Edited
Kevin_A Here is a comparison of 2 hours at HGC vs 3 hours with reducer at Gain 198.
No contest, IMHO. But you also spent more time, and the system already collected more photons per pixel with the reducer.
You might be able to get rid of the CA by using something like one of the Astronomik L-1, L-2, or more extreme, the L-3. One of those should eventually be enough to rid of the purple fringe. IMHO, the L-3 cuts too much.
Check out the blue channel response of the ASI2600MC -- it has only dropped to 50% of its own max by 400nm. The L-2, for example, will knock out everything below 380nm from entering the camera, and "pretending" to be "blue" when it is more like UV already.
Because of the camera's spectral response, you really need at least a UV-IR cut filter, even when you are in Bortle 1. A lot of scopes bloat the stars in UV, which then looks like blue because the blue channel of the camera is sensitive to it. Don't trust the UV-IR cut window of the 2600MC.
In fact, I plan on using the L-1 as the UV-IR cut "prefilter" which I described earlier.
I took a flat with the new 77-52mm stepdown ring with the lens wide open and this is what I got. Vignetting and a weird centre spot. The vignetting is less harsh than without the ring but this is on my aps-c. Just thought I would share.
- Edited
Kevin_A Vignetting and a weird centre spot.
I used a pixel peeper and it looks like the bright ring around the center is not really brighter than the center (or barely brighter). All measured 125 or so on 8 bit scale, and falling as it gets farther fom the center. The human eye is playing tricks :-).
This is intensity vignetting, though, and has nothing to do with the diffraction pattern (aperture vignetting; i.e., non-symmetrical illumination). Different animals. Given just this image, you cound get, or not get, diffraction spikes. Only a star test will tell us if it is clean of diffractions.
BTW, re that Horsehead taken with the IDAS NBZ. IDAS has reissued an NBZ II, and I have one on the way. Should work well with fast lenses. The NBZ II is narrower, 10nm H-alpha, 8 nm OIII, instead of the original with 12nm at both wavelengths.
- Edited
Kevin_A I will test it out but compared to the prior results the vignette is much softer and not as abrupt.
Yeah, you cannot tell from taking flat frames, soft or not. Diffraction spikes appear when the aperture itself is not perfectly circular (happens to both the iris blades and with the aperture vignetting).
If you want to see what diffraction looks like, you can take a Fourier Transform of the images that I measured (the bright central part), and you should be able to see the diffraction spikes . Same as Bahtinov Mask -- take a Fourier Transform of the Bahtinov mask, and you see those 6 spikes. The Fourier Transform of a perfect circle is a J1 Bessel function, and that is the familiar "Airy pattern." You need real math for this. (Out of focus diffraction is actually even more interesting -- you need to multiply the Fourier kernel (i.e., exp(-ift))by a quadratic term in x, y (where x is radial distance and y is the distance along the optical axis. Pretty deep math, but I found a Purdue class lecture that talks about this, if you are interested to discover the secrets of diffraction patterns (Maskulator does not implement out of focus diffraction pattern, by the way).
- Edited
w7ay unfortunately my brain suffers from short term memory issues so much I can’t retain new things. I keep all documentation on record so I can jog my memory for recent tasks. My long term memory is ok but I think I just have to stick to physical testing as even reading is hard these days and it puts me to sleep immediately and I have to read it multiple times to retain any of it. Getting old varies in each of us and I am afraid my brain is on its way out. Thats ok as long as today is fun and I won’t worry about tomorrow! I need a Time Machine to get back to where I could remember what I read an hour ago! Haha the only good part of this is that I can use this issue with my wife… as I tell her when she is telling me something…that my brain is full and is not accepting anything anymore! Haha
For now I will do physical testing with my filterless filter and my lens wide open, plus a quick test with the blades at f2.4 and see how it affects my images in both scenarios! Let me know how yours turns out and I will post when the skies clear! Maybe we should start a new thread as I am getting a bit off topic regarding original thread topic of the 585mc pro! Haha
Cheers!
- Edited
Kevin_A Let me know how yours turns out and I will post when the skies clear!
Not a chance my skies will clear before yours :-). (Yeah, it is raining at the moment.)
I don't take the covers off my mount when there is a chance of rain, :-).
By the way, I have an NBZ-II coming my way next week. I also have a 365nm LED flashlight that I can subjectively test to see how good various UV-IR blocks are. When the NBZ-II appears, I will parade my dozen or so filters that claim to block UV.
Not a great way to measure (the center wavelength of that LED can be 10nm off). I don't have a good white light source for my spectrometer, unfortunately; and most cheap (less than $20,000) spectrometers cannot measure the blocking aspect to the dynamic range that just measuring the max ADU of a frame with a flashlight in it, anyway).
But at least I will be able to tell what blocking filters actually blocks UV, and which are bogus. A quick test in the past has shown the ZWO UV-IR block to be placebo - caveat emptor; but I should be able to compare it with other filters next week. I had kept it around just for such an occasion.
UV will excite the blue channel of a sensor, and will look blue in an image, even though it is way past violet. Without a controlled experiment, it is not easy for an unsuspecting customer to buy a UV-IR cut that is placebo (well, not placebo in terms of losing money). 365 nm should be past the point where a decent UV cut filter should work, so any significant energy that is passed to the camera sensor at 365 nm will indicate a moderately poor UV-cut filter (thus giving blue fringes around stars from an OTA that whose spot diagram bloats in the blue side of the spectrum).
This collection of spot diagrams is from a Cloudy Night posting. Notice the blue bloat from an Askar even at the optical axis (0.00mm). The spot diagrams may not be scaled properly, but you can see the blue bloat clearly on the Askar.
We'll see how my simple tests will turn out. I bought the flashlight a couple of years ago to use for bonding the UV-sensitive epoxy (like the kind used by dentists today). Have to find my UV blocking goggles too :-).
BTW, ZWO swears up and down that their color ASI2600MC uses an UV-IR cut window (see the last few posts in the following foum thread - some very recent). I happen to also have a pristine (never opened) ZWO D60 IR-CUT filter for just such an occasion. We'll see if the 60mm glass window is as poor as ZWO's 2" mounted filter. If it is poor, it is time we expose some of the marketing nonsense. The curve is from a Agena page -- notice that they claim a brickwall at 400 nm, we'll see if even a cheap Optolong UV-IR cut beats it.
https://bbs.zwoastro.com/d/13239-asi2600mc-protective-window/5
They also do have an AR version of the 60mm, and I might have installed it in my ASI2600MC. So, using an external D60 glass is the only sure way to measure the window.
Kevin_A they were the two spanners I was looking at as well.
Received the V spanner and it worked really well. Saves a lot of time adjusting the jaw size. I used it to remove the 46mm K&F filter, in fact (they really torqued the ring -- not sure I could have opened it with the parallel bar tool).
However, be aware that the V will only open so much (86mm filters). For 105mm filters, you still need to use the parallel bar one.
