Kevin_A Can you post a photo of what it looks like without the lens hood on with the ring setup on?
OK, first the stepdown rings by themselves.  This first image is for the case of a single stage step-down (77mm-40.5mm):
The large disc is the stepdown ring, and the protrusion is a 40.5 UV filter with the glass removed.  Nice thing about camera filter sizes is the lens caps that are available; shown on the right of photo.
I could not find any 77mm-39mm stepdown ring, so the next photo shows a 55mm-39mm step down mounted on a 77mm-55mm stepdown, with a 39mm UV filter mounted on the 55-39mm ring, with its glass removed:
Now, the clear aperture of the 39mm filter is not 39mm of course.  In the case of the Tiffen, it is 33.7mm (thus the f/4).
OK, finally, here is the ring mounted on a Rokinon.  The camera band is from Astrodymium, and I had drilled and tapped the 3D material and also the body of a ZWO EAF to directly mount the EAF on the tube band.  Notice my temperature probe hack on the EAF :-)
The lens hood works as normal (since photographers need a lens hood when they use filters),
By the way, did you notice something in the Alioth image?  It completely lacks any diffraction spikes.  This means there is no aperture vignetting at f/4, when done this way.  If there is any vignetting, you will see two "negative diffraction spikes" around a star, as  discussed here (last post there is the best one; I have a similar program for macos as the Maskulator that I had used to find the inverse filter for non-blind deconvolution; my program can actually also control the intra-focus and extra-focus positions too):
https://www.cloudynights.com/topic/547028-anyone-know-what-causes-this-artifact-on-bright-stars/
So, it is perfectly safe to do f/4 aperture control this way.  I will need to test the other aperture for vignetting.
Again, here is the clear aperture (and 135mm f-number) for various step-down rings and Tiffen filters:
"Thread" is the stepped-down thread, i.e., "67mm" indicates a 77mm-67mm step-down ring.  For an f/2.8, try either a 77mm-55mm step down or a 77mm-52mm step down, together with the 55mm or 52mm Tiffen UV filter.  The nice thing about the cheap Tiffens is that they seem to make it for pretty much any size.
BTW, be careful when you buy from Amazon, that the ring is a step-down ring.  A step-up ring (filter that is larger than camera lens) will not work.
