Kevin_A lots of reported problems with backfocus and tilt and coma
Yep, you would expect that from an f/3.8.
The scope comes with an internal tilt adjuster, and backfocus is a problem only for those who don't know what a flat field actually means -- the unwashed use the "radial-stars vs circumferential-stars" hobbyists rule of thumb, which is highly inaccurate. Just use the definition of the flatness of the image plane, and the problem is manageable.
I read a Cloudy NIght thread on the Plieades 68, and the OP complained about coma, when he didn't even set the correct backfocus! WO's web page has copious warnings that this sope (vs the Cat71) is not meant for novices. Click on "Which Telescope to choose -- Plieades 68 or Cat71 WIFO." Read between the lines, and they try hard to not use insulting words for the Cat71's target customers :-)
https://williamoptics.com/products/pleiades-68
I don't even believe their "exact 55mm" backfocus claim. I'll bet they build these in China, and you get Chinese QA. But that is easily measured -- just need a high resolution Bahtinov mask, not their rough plexiglass one. All the free WO Bahtinov masks are worth exactly what you paid for them.
I'll pull the trigger and spend some time tuning it as a project. If the optics is OK, the mechanical issues are not insurmountable. The 260mm at f/3.8 is just too tempting. (I may have to aperture mask it down to a 60mm/f4.5, though; we shall see.)
I downloaded their documentation, and unlike ZWO, is quite detailed. Publishing spot diagrams in the User Manual is a good sign that they care.
I have had problems with their scopes… returned two and sold next one fast.
Yep, my experience with the first generation Cat51 (mine is white), too. Optical quality is very good, but has a bad tilt. And I have been avoiding WO like the plaque until now.
From the spot diagrams, this is obviously not even close to a Tak, but pretty similar to spot diagrams from the better Askars. Notice that they don't cheat like Askar either. Tak and this WO uses a 100µm x 100µm spot diagram, while Askar uses 200µm x 200µm to make it appear to be better :-). Unfortunately, Tak don't make short focal length Astrographs -- I would buy one sight unseen.
