Kevin_A  I never got to my iris as mine has electronics and that adds another layer of complexity.
Ouch, I thought you said you got to the iris.
OK, this project is definitely in the backburner now; perhaps buried for good.  I will try to put things back to as normal as I can, and see if I can still get a working lens, without the aperture click stops (still have no idea where that ball goes into).
I don't like redneck engineering; working with no documentation.  Life is too short for that.
Started to work on the Sigma 40 already.  I am just going to modify the base plate of the Rokinon, seen here with a 1:1 printout and the Sigma to measure where to move some of the holes, and to figure out if I have the right belts in my stockpile.   Perhaps send the design out before the next workweek for the web machine shop to work on it.
Speaking of belts, it really helps using 10mm belts instead of the 6mm astro hobbyists seem to like to use.  Everything feels more solid.  Well, that extra bearing to hold the EAF shaft definitely does not hurt either.
That Blue Fireball CAA that you see in the photo above, really helps in this case, belt or no belt.  That tripod ring does not allow the lens to be rotated.
I am still trying to get used to the Nikon's left-handed bayonet!  I keep tightening the bayonet when trying to remove the lens, and wonder why the bayonet does not even budge :-) :-).
I am still on the look out for the Sigma 40 with an EF mount.  I don't think a new one exists on this planet anymore.
