Kevin_A I need a few good clear nights to retest my old Rokinon and see how it looks focussed to neutral and to retest for aberrations at that setting.
The 40mm Sigma is really well QA'ed.
After spending hours (more than one night) adjusting backfocus.  What I eneded up is a backfocus that caused the line in the focus window to point precisly at the center of the infinity symbol!
I.e., the backfocus is at precisly where they have designed it.
The key for me is to first remove tilt, and only then tune backfocus.  I could have save a lot of time if I had started doing that in the first place.
I had a set of larger (102" diameter) tilt plates made and it is heading my way right now.  This next design will clear the entire cylinder of a 90mm ZWO camera, and will allow me to adjust tilt with a very long 2mm hex wrench from way back of the camera :-).  It should make adjusting tilt and backfocus a breeze (like the two-plate-tilter allows you to adjust the tilt of an ASI2600 from the back).  It is worth the money for the new tilt plates to prove this to myself.  Paying money for knowledge is the most worthwhile thing one can do with money.
made by Samyang optics so maybe I will have better luck with their house brand than rebrand.
I'll bet they both go through the same fingers and hands at Samyang.  I don't think they have different factory buildings for the two labels.
Every internal element that I have looked at are identical between two Samyang 135, and a Rikonon Cine.  The only difference I have found so far is the number of brass shimming washers for the front lens group.
Even the three stupid small black screws are the same :-)
But... there is a different Rikonon 135/T2.2:
https://www.adorama.com/rkx135c.html
Much more mullah, and with huge lens hood -- 114mm.  It touts close focusing -- if that was their design goal, it is a complete waste for astrophotography.
But (ha ha) it has 11 iris blades, so 22 pointed spikes.
