• Images
  • First Light with new ASI585MC Pro.
Kevin_A Do you plan on having the chamfer face forward when you glue it in place? It looks like that would be the logical choice!
I had the beveled part facing the front earlier, since the "front" was where I also placed a 0.5mm deep blind hole to allow me to center the ZWO retaining ring.
When used without the retaining ring, my first instinct would be to keep the machined beveled part facing the sky, since the machined portion is not anodized.
By the way, the hole is not 2.8 times smaller than 135mm. Their f/2.0 hole (when the iris is fully opened) is 29.65mm (it could be 30mm; 29.65 is what my calipers gave me). So the f/2.8 hole that I am making is just going to be sqrt(2) smaller than 29.65mm.
    w7ay i wonder if a good contact cement applied in 3 thin even circles would work. I have thin double sided carpet tape that is super sticky but it may move. I used it on my drafting table I just rebuilt as I could not find the original tape used to mount the green front surface. A good RTV silicone may work too but it would have to sit awhile while the out gassing stopped. A lot of adhesives and glues have so much fumes in them the lenses would probably fog up. I like epoxy but it is too brittle but jb weld steel is a bit better if it has a good roughed up surface.
    • w7ay replied to this.
      w7ay i usually take my matte black spray paint, spray some into the cap and use a tiny throw away brush and paint the edges of things and then put it in my oven for 30 minutes to cure it and get the fumes out of the paint so it cannot transfer anything to fog up my optics.
      Kevin_A very frustrating hobby when mother nature has the last word!
      After 60 years in this hobby, I don't really care about clouds anymore. I just do something else than take TikTok pictures (which I can now do with my iPhone, ha ha).
      I just started gathering the parts I have (OAG, tube mounting rings, camera angle rotator, etc) to see if I can assemble a laser jig for measuring camera tilt. Clouds would be noo problem.
      The only precise part needs to be the camera angle adjuster, which must have no tilt (if it has tilt, it cannot be used on an OTA anyway :-).
      It really is just a fun project because I have always wondered if I can use two cameras facing one another (one is device under test, and the other to record the result, instead of using a pen on a piece of paper -- so 19th century :-). And with the laser beam injected with a small mirror (like a Newtonian diagonal, used backwards). In this case, the prism of an OAG. I have a couple of (Askar and Orion) OAG sitting around. Each time I am temped to use one, I'd reject the idea because a separate guide scope is so much closer to ideal (as long as there is no differential flexure). Heck, with the sloppy helical focusers on these OAG (especially the ZWO ones, which I won't buy even to test), a separate guide scope is probably more solid. OK, that is my daily rant on autoguiding :-).
        Kevin_A A good RTV silicone may work too
        Ah! That is a good idea. Just a small drop of it.
          w7ay i gave up on all OAGs awhile back and just use guide scopes with the mounting screws very tight. OAGs were never good quality stars in my opinion since you have to use an inferior part of the flattener when using a bigger sensor camera for imaging.
            w7ay Ah! That is a good idea. Just a small drop of it.
            Like I said…. I am not a brainiac… just a good catalyst for other better glue makers! Haha
            I need a few good clear nights to retest my old Rokinon and see how it looks focussed to neutral and to retest for aberrations at that setting. I just do not want to pull apart a lens that will never be good anyways. I am going to try ordering a Samyang version too as my latest Roinon said on it… made by Samyang optics so maybe I will have better luck with their house brand than rebrand.
              Kevin_A OAGs were never good quality stars in my opinion since you have to use an inferior part of the flattener when using a bigger sensor camera for imaging.
              How true that is.
              If the part of the image plane where the OAG resides is good, why not use it for a larger image, instead of wasting it on an OAG :-).
              Except for 16" SCTs, I have never understood why people like using OAG. Nor the "Duo" cameras.
              SBIG gave up after inventing the "duo" scope and sold as the ST-7. ST-4 was the first and the last camera to have two chips. ST-4 was the first camera that had the guide pins, that is why those pins are called ST-4 today.
              http://www.company7.com/sbig/products/st7.html
              I still have my SBIG 8300; that one once had the reputation that the Sony IMX571 based cameras enjoy today.
              I regret sending Sam an email about the two camera ST-7 a year or two ago. He got one of his flunkies to jury rig one up (guy used to do product support, not engineering). But I'd warned him about all the shortfalls of a dual camera system, which he of course does not include in the Duo documentation. To ZWO, everything is a rush job to get the next bundle of money. And then abandon support to go the the next money making scheme. Nothing is studied properly.
              I also now regret telling Sam about how well the RST-135 worked as a mount. He went off and copied that too, but without really studying the minutiae of the RST-135. It puzzles me (... it is a puzzlement... The King And I) the Chinese blindly copy things without first trying to understand how they work. The leaky tantalum capacitor was a good example, and exploding LiON batteries is another. Both were missing a critial ingredient that stabilized the chemistry. The copied (stolen IP) ones lacked them cause fires, and I think the expolding batteries caused lives to be lost.
              At least the ZWO mounts won't kill anyone, and it serves them right, now that the Chinese are copying themselves, and with more stable mounts. At least two companies now have starin wave mounts with much better measured guiding -- only one of them recently distributed in the US by Agena. They all use the same strain wave gears; so we know the tracking glitches are how ZWO is incorporating the gears, not the Chinese gears themselves. In addition to real EE who can design USB interfaces, ZWO also needs to hire real ME who can design mounts.
              After those two things, I have now sworn off telling Sam about neat ideas to implement. I was expecting him to start some real investigation, but he simply took off and got his people to copy things superficailly. Unfortunate for the ZWO mount customers, I don't think there is a way to get rid of the mount glitches short of a full recall (like they did with the leaky ASI2600), and I don't think they will do that.
                Kevin_A I need a few good clear nights to retest my old Rokinon and see how it looks focussed to neutral and to retest for aberrations at that setting.
                The 40mm Sigma is really well QA'ed.
                After spending hours (more than one night) adjusting backfocus. What I eneded up is a backfocus that caused the line in the focus window to point precisly at the center of the infinity symbol!
                I.e., the backfocus is at precisly where they have designed it.
                The key for me is to first remove tilt, and only then tune backfocus. I could have save a lot of time if I had started doing that in the first place.
                I had a set of larger (102" diameter) tilt plates made and it is heading my way right now. This next design will clear the entire cylinder of a 90mm ZWO camera, and will allow me to adjust tilt with a very long 2mm hex wrench from way back of the camera :-). It should make adjusting tilt and backfocus a breeze (like the two-plate-tilter allows you to adjust the tilt of an ASI2600 from the back). It is worth the money for the new tilt plates to prove this to myself. Paying money for knowledge is the most worthwhile thing one can do with money.
                I'll bet they both go through the same fingers and hands at Samyang. I don't think they have different factory buildings for the two labels.
                Every internal element that I have looked at are identical between two Samyang 135, and a Rikonon Cine. The only difference I have found so far is the number of brass shimming washers for the front lens group.
                Even the three stupid small black screws are the same :-)
                But... there is a different Rikonon 135/T2.2:
                https://www.adorama.com/rkx135c.html
                Much more mullah, and with huge lens hood -- 114mm. It touts close focusing -- if that was their design goal, it is a complete waste for astrophotography.
                But (ha ha) it has 11 iris blades, so 22 pointed spikes.
                  w7ay zwo must have copied their ALT/Az implementation for their AM5 from the Skywatcher Star Adventurer… it takes me 15 minutes to get my PA dialed in with their coarse crappy large pitch adjusting knobs. My god my SA is actually better. It would have cost nothing to use a very fine pitch for PA adjustment….rush rush rush copy copy copy.
                    Kevin_A it takes me 15 minutes to get my PA dialed in with their coarse crappy large pitch adjusting knobs.
                    I do not think the person who designed that has ever polar aligned a mount in his/her life.
                      Yes they have a few different models all made as you say probably on the same line. Even the Xeen is made there too. I see 3 other versions… manual 135 regular, DS cine and DSX cine versions…. All same internals, 2 de-clicked and one with weather sealing… except on Nikon version. I will try the Samyang version just for kicks and see.
                      w7ay Emcam Astro has a new mount offering that has a nicer and finer PA implementation. Not sure if they are china brand but think so.
                        Kevin_A Not sure if they are china brand but think so.
                        Yes, Chinese company in Shanghai (so not that far from ZWO). Uses the same Chinese strain wave gears as the larger ZWO mount, but are much better mechanical engineered. My mom was born in Ningbo, across the river mouth from Shanghai :-).
                        But I think it is emcan astro.
                        https://emcanastro.com/about/
                        Have you noticed that none of these Chinese copycats can make a mount that weights as little, nor as compact, as the RST-135? They also have god awful hand controllers. The Hubo-i handcontroller for the RST-135:
                        https://www.ganymedes.nl/wp-content/uploads/2021/03/Hubo_i_for_RST-135_Manual_ENG_v1.0.pdf
                        The handcontroller manual alone is larger than the manual for the entire ZWO mount :-).
                          w7ay yes, Emcan… bad 1 finger typing on iPad. Haha.
                          By the way, Kevin, have you thought about spreading the payload of your ZWO mount sideways (e.g., using a side-by-side mounts, like I do with my dual saddle plate) instead of stacking stuff taller, and thus further away from the RA axis?
                          All the way back to the RST-135 (and perhaps even further back to Hobym), stain wave mounts have emphasized the need to keep the moment arm short. Emcan claims that they have designed their mount so the declination plate just 80mm away from the RA axis. I just measured my dual saddle plate, and it is 75mm away from the RA axis .
                          My dual saddle plate itself adds another 10mm (flexture? whats that?), and a PrimaLuce Losmandy dovetail clamp another 25mm or so).
                          The more I look at the Emcan mount, the uglier it is (although not as ugly and with gaudy colors as the ZWO mounts). Just compare to what the RST-135 and RST-135e look like. The Chinese mounts look like they were designed by Neanderthals. Years at Apple has taught me that well engineered stuff don't have to also be ugly.
                            w7ay it is interesting that you said the Sigma focussed exactly at the centre of the infinity mark as that made me think about my Tamron. I just tested that lens again on my Nikon Z7 and it too focussed precisely at infinity right in the middle… but on my cooled camera with a filter was closer to the 3’ mark…. Hmmmm, i will have to recheck that as maybe the zwo sensor back spacing on my 183mc pro camera is off a bit or my stack was off. I tested with that low end camera due to the smaller pixel scale. I never have issues with getting rid of amp glow but holy noise cow!
                            I wonder why adding 0.62 for a 1.85mm thick filter would throw it off so much and I did get bad stars on the cooled and better on the Z7. I will recheck that too next clear night as I think something was amiss. It is amazing how other peoples comments opens up thoughts regarding one’s own projects and conquests. Thanks… haha
                              w7ay I have thought about side by side but remember I am using a AM5 mount… so would I really see any gains? Haha. It runs fine then not.. so it is not an issue with lower consistant RMS but rather an issue of inconsistancy… and that cannot be changed by a shorter moment but rather by a better set of gears! Haha my mount is like a gear that has a section where the teeth are missing on it…. Runs fine then crap hits the fan every 30 minutes for a few minutes, then fine again. But hey…. It has been better than my last 2 iOptron mounts that both needed over 6 different parts replaced each after 1 month of use. Even iOptron was surprised how bad they were. I still had to pay $300 each to ship to get them to fix. So…. For now I will take the 50 minutes of good images an hour from my crappy AM5 and shut up as I know it has been worse in the past. Nothing like ripping apart my iOptron mounts every other night and trying a few hundred things and still not get it to run under 2”rms even though I know how to set bearings perfectly and set a mesh fabulously… only to be frustrated night after night by badly machined and put together parts. Ok, rant over! Haha so I am good having a longer moment for now…. At least I am imaging this year and last year compared to 2 years of no good imaging.
                                Kevin_A but on my cooled camera with a filter was closer to the 3’ mark…. Hmmmm, i will have to recheck that as maybe the zwo sensor back spacing on my 183mc pro camera is off a bit or my stack was off.
                                That is almost for sure wrong backfocus.
                                I just checked the Samyang 135 that I fooled with backfocus the other night -- the middle line of the depth of field scale points.... right at infinity mark.
                                When I get the larger tilt plates in, I am going to keep the EAF and focus right were it currently is, and start tuning the Askar backfocus adjuster for best focus with a Bahtinov mask.
                                  Kevin_A t runs fine then not..
                                  One day, you too will stop buying mounts from China.
                                  With mounts from Korea, Japan, Italy, Greece, why would you even get near a Chinese mount?
                                  Would you buy a car from China? If not, why would you buy a mount from China?
                                  At least get a Taiwan mount.
                                  Rule #2: stay away from things that are shilled on YouTube. Have you ever seen a YouTube shill gush at a 10Micron or AstroPhysics mount, or an RST-135? Nope. And yet, there are plenty of those being used (just check Cloudy Nights).
