Hello,
I noticed when I am using the ASI1600MM Pro on either ASI Studio 1.11 and SharpCap 4.1, when I set the exposure setting to 2 seconds or higher, everything is working as it should. When I set it to any exposure back below 2s, it fails to get the image unless I set it back it back to 2s or higher. Only fix I found is that I have to unplug the camera and plug it back in then I can control the exposure below 2s just fine and get images. Once I pass that 2s and above is when I can't get exposures below 2s until I unplug/plug the camera back in.
I tried this with ASI Cap 1.6.2 that I still had installed on this computer, and I am able to set the exposure to any rate even after setting it to 2s and higher, everything working fine through that program. It is just with ASI Studio and SharpCap that has this issue. In the SharpCap logs, it is saying that it has dropped frames of type ZWOTimeout.
I also tried setting the USB traffic, changing between 8/16 bit, binning modes. Just simply had only the camera plugged in, nothing in its hub to nothing else connected on the computer. It just doesn't seem to change anything until I unplug/plug the camera. I have installed the latest drivers for the cameras (V3.24 and ASCOM V6.5.25) and checked the firmware installer and can't find any firmware files to install for the 1600MM. (The Firmware software says that Camera has firmware V5.0 and FPGA firmware 1600 V.03--1.1.2.7)
Is there anything about this issue or what I can do?
Thank you for your time.
