- Edited
Status update for testing 2.2.2
I had a full night of imaging without issues. PA, Autofocus on filter and temperature change, plate solve on plan mode targeting and WiFi - ALL worked for a full night without any issues.
Hardware used ASIAIR plus, AM5 mount, ASI533mm main camera, ZWO filter wheel, ASI278mm guider, ZWO EAF. LX200 8" EMC with Starizona mark IV corrector reducer giving final 1414mm focal length. Guider William optics 50mm at 207mm focal length. I noticed guiding was not using saturated stars as previously noted. A note about WiFi on ASIAIR. I only used to option to connect to my home network at 5Ghz - I did not use AP mode. I previously modified the ASIAIR wpa_supplicant to define my correct country code, not CN, and added priority sections for 5Ghz followed by 2 4Ghz for my network.I also was logged into the ASIAIR via SSH so I could monitor logs not normally available as I was expecting problems however I had no issues. I had no disconnects or any issues the entire night from 7:30pm to 6:15am. Guiding may have been slightly worse the normal but well within the pixel scale I was using. Stars nice and round.
I will give more updates as use it more -hoping for clear weather later next week ..
PS I modified my ASIAIR previously to permit SSH access. I use a Linux system to back it up fully every so often and to automatically download images and classify them.... I only changed the authorized-keys files and wpa files - nothing else
