PMTeam@ZWO Thank you for responding. I'll answer each question.
On the matter of plate solves, yes, I focus first. I use a 10 second exposure. The software reports many stars, but plate solves fail. If I use the all sky method, and your alternate plate solve method it works perfectly.
It doesn't seem to matter which filter I use. Tonight I was using an Antlia HaOIII filter. I see plenty of stars on the first exposure.
I connect to the camera WiFi in station mode. The drop outs occur in either 5gHz or 2.4 gHz. For reference my ASIAIR pro and plus worked perfectly from the same location.
I did not see any corrupted downloads tonight, but that seems a random occurrence, and it could happen any time. I'm not imaging overnight unattended, because when one of those corrupted files comes through it messes up each following file.
On the freezing on loading issue, I have sent multiple logs that should help you find what is going on. I have also sent logs when I get a corrupted image. One other person on this forum had the plate solve failure issue when polar aligning.
Hope this is helpful.
