azskyguy
Regarding the PA problems, I can't speak for the v2.3 Beta software, since I am still running the official v2.2.2 release from the App Store.  I suppose it's possible some problem could have been introduced in the Beta.
However, I have had problems doing PA with all of the software releases for over a year, when using a narrowband HaOIII filter.  The problem is especially noticeable on my f/10 reflector with long focal length.  The same problem also occurs on GOTO when I have auto-centering enabled on the ASIAir, since that requires another plate solve.
When I removed the filter during PA and GOTO, then all the problems went away.
So these days I make sure I am using either no filter or just a wideband UV/IR cut filter during PA and GOTO, and then I swap in the appropriate narrowband filter (for nebula) during stacking.
