The new version has been released.
New Features
Optimizations
You can download it from app store or here. https://www.zwoastro.com/software/
Tech@ZWO Didn't fix the filter bug. It's still not turning filter on auto, must do it manually.
Hello What is continous shooting in stargazing?
satch984 no enhancement but save every frame
And where is the mosaic option that's been promised for months?
Sofarsogood That’s the framing option
Sofarsogood
Framing
Sofarsogood FYI
Nice update with many new things and the UI seems more clean and responsive. A few typos in the documentation but i have reported this via the app.
One thing i did not understand was the "Added message push". There is no explanations for what this does.
For those whom it may concern: read that damn tutorial before you ask! The answers are in there for all your questions. Continuous shooting, mosaic mode, etc. Read, read, read!
Gulyas K nicely stated. Thank you.
I would be delighted if the manual and the tutorials were available in an easy-to-read and up-to-date version as a PDF and not just as tutorials in the app. There they are difficult to read due to the inverse font. Apparently, some of the tutorials are only accessible via the three dots when the Seestar is switched on. In addition, they are apparently not completely up-to-date with the current interface of the app. I would like something that I can read during the day before watching in the evening.
Brille https://h5.seestar.com/course/ However the Level calibration method in the tutorial is not too useful, indeed. Open the arm, put a bubble level on Seestar.... This is how it DOES NOT work, because to read the bubble level accurately, you have to look at it direclty from the top. Which you cannot do, because of the arm.
Brille Got it, i conveyed to our team.
Gulyas K You should use the "bubble level" in the app. What i'm doing is to level the tripod then add the S50.
Yes, I would like to look into a Manual outside the App. Regards Corner
I downloaded the new version all right but didn't get the tutorials. How do I fix that?
Great update!
Framing mode is the best way to avoid field rotation and increase resolution, very very nice.
