Tech@ZWO For the session described above (which was not the last of the night) it was clear skies, no clouds, trees or other obstructions during the entire time. It ended at 12:56am local MST, but last sub file for that session was at 12:09am.
I ran another session after that and it did end when the target moved below the roofline of a building, so that one can be ignored. Last sub file at 2:36am MST, session ended at 2:42am.
This same issue has played out time and time again (3 nights in a row).. At 1.4-1.5x framing, it gets about 22 minutes of exposure over an hour or so of real time, when it's coming around to image that upper left corner of the mosaic and starts failing to stack there. What I notice each time is that corner shows visually high sensor noise, and if I stop it there the live preview shows that there's not a lot of stars there. Since an hour has passed there's about 15 degrees of sky rotation, my hypothesis is that it is having a hard time aligning the few stars against the noisy corner from earlier pass. Because it appears to spiral outward to build the mosaic, there's more and more sky rotation every time it gets back to that upper left corner. For the earlier session last night, it eventually figure out how to stack that corner after about a half hour of failing, and that's where I got another 7-8 minutes of exposures, and then failed again yet again in the upper left corner on the outermost pass of the spiral, as described above.
If I recall the entire time it was failing it claimed there were star trails.
