Surfwheel49
Regarding the issue you mentioned with EQ mode not properly framing objects in Framing/Mosaic Mode, we suggest checking whether you have selected the correct target. If no target is selected or the target position is not accurate, it may cause the frame not to align with the object. Make sure the target is properly selected and within the frame, as this will help the device align and capture more accurately.
Additionally, regarding unknown objects, we have already added some new asteroids and celestial objects to the Seestar Atlas, and we plan to continue adding more non-NGC objects in future updates. For the objects not currently included, you can also manually input the name, which will help the system better locate and track the object.
If you have any further questions or need additional assistance, feel free to let me know! Thank you for your support!
