Jeff P Yes, in ALT/AZ mode, the FOV frame is oriented based on the current time of day, which can cause a shift in the framing when you're planning observations. However, in EQ mode, the framing should be more stable since it's aligned with the celestial coordinate system, which is not affected by time of day.
To make a plan based on EQ mode framing, you can follow these steps:
- Switch to EQ Mode: Make sure your Seestar device is in EQ Mode before planning your observation.
- Select the Target: Once in EQ mode, select the celestial target (like a star, galaxy, or nebula) you want to observe. The software will automatically adjust the framing according to the equatorial coordinate system.
- Plan Your Observation: After selecting the target, you can proceed with your observation planning.
This approach ensures that your framing will stay aligned with the sky's equatorial coordinates, not influenced by the local time of day or the altitude/azimuth position.
