If your Seestar is connected to your home WiFi network, you need to find its IP address and then in Windows Explorer enter the network address formatted like \192.168.1.123\EMMC Images\MyWorks\ in address bar
It should immediately connect.
If access error:
You may need to allow "insecure guest access" so that you can access the SeeStar guest id:
Open gpedit.msc and navigate to Computer Configuration > Administrative Templates > Network > Lanman Workstation
Find "Enable insecure guest logons" and enable it.
