I have a new 2600 Duo and have been unable to use it for imaging and guiding at the same time. If I have both cameras connected to my ASIAIR Pro or Plus, I get either an exposure failure when I try to take an image or if I try guiding, I get an error message to the effect that it cannot take an image. However, if I unselect the Duo's guide camera, I can take images just fine. I've swapped out USB cables and have the Duo on a separate power supply capable of 12-13 volts @5 amps. I also changed USB ports.
Tech support suggested I upgrade to the latest ASI software, but that did not resolve the problem, and when I replied back that I am still having a problem over 2 weeks ago, I still have not heard back from anyone.
Is there a basic problem with the Duo or do I have a bad unit?
