@PMTeam@ZWO
Wanted to share my issues when I first tried the new 2.4.4 version. My experience with the new version is disappointing. Below is my setup and issues I discovered:
Mount: ZWO AM5
OTC: Edge HD 8"
Camera: ASI294MC Pro
CAA: ZWO CAA
ZWO ASIAIR Plus 256Gb
ASIAIR on iPad.
Issue 1: Focus routine didn't work. I selected the focus routine, zoomed on a star and tried manually adjusting using the Feather Touch focuser. No change in the values or refresh did not show any changes to the focus (I have the continuous refresh setting on).
Polar alignment worked without any issue. Once PA is done, then I selected to go to Arturus via the object search. The mount did slew to Arcturus for adjusting the focus using the Bahtinov mask. But didn't center the object. I also noticed that the go to target button has no description saying 'GoTo' as in the previous versions.
Issue 2: Mount slews to the target but plate solve never comes back with failure or success. Just hangs in there. So the object is not centered. Plate solving is broken badly.
