PMTeam@ZWO
Finally I had the opportunity to test the 2.4.1. and can report that the Meridian Flip issue has been solved. Thanks for solving this!
However I observed the following things when using my ne ASI585MC Air and AM5N:
-the guiding values were mostly below 0.3“. As I was imaging with a dual narrowband filter I used 2x2 binning on the guide cam. Normal guiding values are around 0.6“. I assume that binning is not taken into account when calculating the guiding error.
-mount voltage display. Mount voltage was constantly shown as 12v while the ASIAIR voltage showed roughly 12.8V. As I was running from a battery the value in the Asiair declined from 13V to 12.8v but mount showed 12v all the time. This was different with the previous firmware.
-a small issue, in the mount info tab focuser is shown. See screenshot.
Logs are uploaded. BT20250704803200A
Best regards,
Stephan
