No it is not fixed - I want to turn auto rotation OFF, not select 180 degrees then check to see if it has enough cable.
Rotation should be MANUAL, ONLY.
Nobody knows unless you make it self-evident in the CAA settings or document it, in a manual ...
... but you did neither...
Honestly your software people quite frankly are amateurs - I am an electrical engineer and used to run big software hardware and software projects for 40 years - trains, air traffic control, power stations, electricity networks.
You really need to fire them and go find some more professional. I'd even volunteer to fix it for free, if I didn't have a day job that pays well. In my spare time I am also an Apple developer and also write apps for iOS.
I even offered to donate the manual I started, for free, if that will help you get started, but instead you deleted the thread and the post. At least you cannot stop me posting the link on CN. It has had over a thousand downloads.
PMTeam@ZWO
