Once you have confirmed that all files have been successfully backed up, you can proceed to format the Seestar device.
If you are formatting it on a computer, please make sure to select the exFAT file system. Choosing any other format may cause the device to malfunction.
After formatting is complete, reconnect the device using the USB data cable to verify proper functionality.
Note: Formatting will erase all data on the Seestar. Please ensure that all important files are backed up beforehand.
