See the attached image to see what we the users are seeing. When trying to plan in EQ mode, the target window defaults to alt/azimuth orientation, even after changing the grid to EQ mode. The target window should be parallel with the lines in degrees in EQ mode. In this example, that would be the 31 degree line. Are users support to manually realign the frame? Given the software can align properly when setting up to do live using the Sky Atlas, this should also work when doing planning too.
Thanks!
