Tech@ZWO
Hello, thank you for your answer, I use an Asiair plus.
Here is the setup configurations:
Main setup: TS 80/450 (with the reducer), ASI2600MC temp=-5°C, draw filter, connection M63 > M54 > M48
Guiding setup: TS 50/200 with ASI 290MM mini, filter UV/IR cut
Guiding mode: X0,75, 1s, RA & DEC set to 50%
with:
filter Astronomik L2 2", imaging time: 60s
filter Optolong L-Pro 2", imaging time: 120s
filter IDAS NBZ 2", imaging time: 300s
We read so many advices on the forum, that is a little bit difficult to set the good values.
The guiding time is 1s by default, I increase to 1,5s in case of bad seeing (full moon)
The DEC agressivity is set to 50% most of the time (60s for 1,5s)
The RA agressivity is more difficult to set, more often 50%
=> Do I need to go to lower values in case of RA spikes?
The RA and Max Dec guides are set to the default values. In reading Zwo forum, I see I must decrease the values to 200-400ms range value. Is it possible to calculate the good range for these parameters?
What is the good range value for max guide pulse duration for RA and DEC?
I will remake test as soon as the sky becomes clear. I will post here the result.
I wait your recommendations if you could.
Best regards,
Kaelig
PS: due to ZWO is the owner of AM5, perhaps you could implement automatic calculation in order to set the guiding parameters in the good value ranges for this specific mount.
