I’m experiencing the same disconnection issue with ASIAIR Plus when using an iPhone and a MacBook Pro.
In particular:
The Wi-Fi connection remains active and stable
However, the app suddenly loses connection to the device
The issue is intermittent and not easily predictable
In some cases:
the iPhone disconnects while the MacBook can still connect
or toggling Wi-Fi off/on on the iPhone restores the connection
Another important point:
even when the app disconnects, ongoing sequences continue to run normally
This suggests that:
it is likely not a Wi-Fi signal or connectivity issue
but rather a problem in the communication between the app and the ASIAIR (session handling / protocol / possible bug)
In practice, it looks like:
→ the device is still reachable on the network
→ but the app loses the session or the communication with the ASIAIR
For reference:
I am currently using version 2.5.2
I was experiencing the same behavior also with version 2.5.1
I cannot comment on earlier versions, as my previous ASIAIR had a different issue (it would freeze in cold conditions) and was replaced by the retailer
Has anyone else observed the same behavior with the latest versions?
