new install of ASIAIR Plus 256GB
firmware: latest, applied by the mandatory V3.0 update
triggered on first power-up
ASIAIR app: V3.0
Nikon Z6II - firmware 1.70
Mount: ZWO AM3N (connects and slews normally)
Every capture attempt returns "exposure failure." No image file is produced -
nothing transferred to the app, nothing written to the camera's memory card.
WHAT WORKS
- Camera is detected and appears in the device list
- Exposure settings changed in the app propagate to the camera body correctly
(set 1s in app, camera display updated to 1s)
- N3 shutter cable fires the shutter audibly on command
- Camera writes files normally on manual shutter release
- USB cable verified data-capable: same cable transfers photos to a PC
WHAT FAILS
Exposure fails identically whether timed over USB (expose-via-shutter-release
OFF, real shutter speed) or via the N3 cable (ON, Bulb). Both paths produce
"exposure failure" with no file written to card or app.
CAMERA CONFIGURATION
Mode M, Bulb, single frame, RAW (14-bit lossless compressed)
Long Exposure NR OFF, Vibration Reduction OFF
Setup menu: Airplane Mode ON, USB Power Delivery OFF, USB set to MTP/PTP
Memory card present
ASIAIR CONFIGURATION
Expose via shutter release - tested both ON and OFF
Save image to camera - tested both ON and OFF
Tested in AP mode and Station mode; device activated
ELIMINATED BY TESTING
- Power: dedicated regulated Mean Well 5A supply, no other load
- USB cable: verified transferring photos on a PC
- USB ports: tested on both USB 2.0 and USB 3.0 ports - identical failure
- Camera hardware: manual shutter produces files normally
- Boot order: camera-first-then-ASIAIR, and ASIAIR-first-then-camera
- Trigger method: both USB-timed and cable-timed fail identically
LOGS
Log upload from the shooting page shows no entries to upload, with the ASIAIR
connected to the network and after reproducing the failure.
TIMELINE
This is a new installation. The mandatory V3.0 firmware update was triggered on
first entering the shooting page. I have never had a successful capture with
this device.
QUESTIONS
ASIAIR V3.0 is documented as involving "major underlying firmware upgrades"
with a mandatory update. The V3.0 release notes make no mention of
DSLR/mirrorless capture handling. Was external camera capture affected by
the V3.0 firmware changes, and are there known Nikon Z6II regressions?
Is the Nikon Z6II fully supported on the ASIAIR Plus 256GB, and at what
minimum firmware version?
Why does log upload show no entries after a failed capture?
If this is a V3.0 regression, is a downgrade available, and is there a
supported procedure for the Plus 256GB (eMMC, no removable card)?
any Ideas?
