PMTeam@ZWO
I couldn't reproduce it myself during the night, and the remote mode worked more or less fine 🙂 .
I saw one problem though. When I create a hotspot in android and let the asiair connect to it, the ip is in the range of 10.X.X.X (but not 10.0.0.X). Well, somehow the app could not connect to the asiair on that 10.X.X.X 'locally' (despite having typed the IP manually), but then through remote mode it was working ok.
Check out the suggestion I made on the re-centering feature. It is probably not a lot of coding to be implemented and it would be amazing to have it in the final 3.0 release. I usually have to crop quite a bit of the margins of my images because of these artifacts between filter changes and meridian flips. So it would be amazing to 'recenter' every time a filter is changed or meridian flip is done AFTER the guiding is calibrated.
