Everything was working well with my ASIAir Pro, then the 8.83/1.8 update happened.
Now:
It no longer automatically does a plate solve on a goto operation. That includes Preview, Autorun, Plan. You have to manually take a preview picture, hit the Plate Solve icon, then hit the button that tells the app to sync the mount and center the target.
Each time the unit is rebooted, the storage defaults to the internal SD card. It use to default to the USB stick, if one was plugged in. Now you have to go into storage management and change the setting to the USB stick manually, every single time.
The preview image is now very purple. This is happening on my tablet and phone, so it appears to be something has changed in the app. The image files themselves are normal, this is just the preview image.
There appears to be no documentation provided to the user about these significant functional changes. I use to be a huge fan of my ASIAir Pro, but between the PL23xx issue and now these problems, I'm not sure I can recommend this product any more.
Why did you change things that were working perfectly? And how do I get my ASIAir Pro to work the way it did before this update? Can you please let us go back to the previous version.
Update: The mount did a meridian flip correctly tonight. The ASIAir did a normal, automatic plate solve after the flip. So at least one area of the app hasn't changed.
Update 2: It looks like the 1.8/8.83 update cleared the "GoTo Auto-Center" setting. Turning this back on restored the automatic plate solving on a GoTo operation. Yay!
Now if I could just find a solution to the SD/USB issue.
