franco An ASIAir Max based on an 8 core Orange Pi with NVme ssd is what I'm hanging out for.
I am not waiting.
Some time ago, when the Mac Mini that has the Apple Silicon (M1) came out, I bought one to be able to experiment with the M1.  (I am in my 70s, but I still play with algorithms for fun.)  At the same time, I found that the Mini had enough processing power that I could replace my 2009 MacPro for most of my needs.
Fast forward to earlier last year -- Apple announced the Mac Studio.  So I bought a 20 core version and stacked it with 128 GB of memory (no, not typo -- I could give AstroPixelProcessor 64 GB of RAM to use as buffer, for example :-).  So, I could retire both the Mac Mini and the MacPro.
At that point, I ripped the AC power supply from the Mac Mini (which only need a single 12V source), and replaced it with a 12V buck/boost converter.  Everything fits nicely into the original enclosure.  The reason for the buck/boost is so that it can be powered by fluctuating battery power if needed.
So, I will be running Indigo on this Mini.  It will have so much processing power that I won't need to upgrade my astronomy setup again.  I had used a Mac laptop in the past, but never happy with leaving a display and keyboard out in freezing weather.
Plus, I can experiment with my own algorithms (actually currently working on simulating an algorithm which I recently came up with, that should work better guiding with strain wave geared mounts :-).  This is also why I am eyeing the Pegasus mount as another test bed for the new algorithm, in addition to my RST-135.  There is no way you can innovate when you are hobbled with an ASIAIR.
