Guys, check this out:
I was happily using my old Asiair V1 with app version 1.9.1, but then I purchased a new Asiair Mini. This Mini naturally came with the newest app version (2.1), and, as I was afraid of, the ASPA is not working anymore. Same issue, the error keeps accumulating by itself.
Now I don't know if I will be able to downgrade to 1.9.1 again with the Mini, since its firmware is updated past the 1.9.1 app version. I actually tried to install 1.9.1, but then when the app is Iaunch, it says the firmware and app versions are not synced. Despite that I'm given the option to ignore this and enter the app, the problem still persists (polar alignmenr error changing at each refresh, no mount/wedge touched). Maybe this is an indication that the problem might lie within the firmware...? Ps.: when downgrading both firmware & app to 1.9.1, my Asiair V1 works as a charm.
Well, at least for me, it's pretty obvious it's an app-firmware-related issue, since downgrading to 1.9.1 + matching firmware instantaneously solves the issue with ASPA.
Now I'm pretty sad I most likely won't be able to use my new asiair mini... ASPA is a must for me.
