I already posted on ZWO ASIAIR facebook + on the Asi533 camera, but so far i never been able to fix that isse, let me explain.
Just started to use and configure a new Asiair Plus this weekend with also a brand new Asi533mc Pro,
The AAP get updated to the v2 firmware version during the initialization process.
I'm using two genuine dedicated zwo 12v 5A power supply. One for the AAP, and another one for the cooled camera asi533mc Pro. ( for test purpose )
Both power supply were tested with a multimeter , and the average output voltage was around 12.35v to 12.2v
( Till now, i'm powering with two independent zwo 120v to 12v 5A adaptor for trouble shooting puspose only.)
As far as i know, the ASIAIR Plus should be able to power the asi533mc cooled camera with one of their 12v output port.
Also just for testing, there is nothing else plugged on the AAP other than the Camera USB3 cable. ( no mounth, no guide camera, nothing else )
I tried to create my dark frames library with different exposures length through the AAP ** Autorun ** , but I ran into an intermitent camera cooling issues where the camera just stopped to get cooled. ( cooling fan intermitently stop and restart just after by shutting down the cooling at the same time )
What i've seen so far, It's happening after a frame get captured by the camera and while saving it and it could be on the internal AAP storage area, or a usb, or on a micro SD too.
At least it's what it looks like.
When it's happening, more than often I'm getting an alarm on my Ipad mini screen, The exposure failed, the auto run stopped
I first thought it was a camera issue with my cooling temp target ( -15c or -10c ) , but even selecting a + cooling temp like +5c was also causing that issue.
For testing I ran the camera through the zwo AsiStudio V1.7 software instead on my laptop, and it ran for about 6 hours to creating my dark library at different exposures, and the camera cooling never stopped while capturing my dark frames at -15c.
So the camera seems to be fine when connected with the same 12v power supply to my laptop.
Lastly last night I retried to build some dark frames in autorun on the AAP , but the camera cooling was still intermittently stoping the cooling fan and the cooling process itself.
I deleted all AAP autorun presets and tried the firmware reset on the AAP.
I tried the Firmware reset twice and it reloaded the latest firmware v2 after the process , but unfortunately I'm still getting that exact same issue.
If anybody have ever experienced something similar and have figured out how to solve it, please let me know.
Regards
Benoit
