- Edited
I completly isolated the power source by using a clean power souce from a genuine ZWO AC-DC 12V 5A power supply that was plugged on a APC ups battery backup.
I also tried to directly plug the ZWO power supply in the wall outlet, but i've got the same result.
As i said before, i first started to power the 533MC Pro from the AsiAir 12v output which was also outputing a steady 12.2V
but the camera cooling was still unstable that way. So from there i stopped powering the 533MC from the AAP and i started to used another ZWO Power Supply ( ZWO-AC-DC12V5A ), but still getting the same issue.
I i said before, when powering the camera alone with the same ZWO-AC-DC12V5A adaptor and controlled through my laptop and AsiStudio, every thing was fine without any cooling issue.
What i'm saying is that even when the camera is independtly powered with a tested and direct power source( ZWO-AC-DC12V5A), as long as the camera is driven by the AsiAir though the AutoRun auto process, it always failed
