After the last firmware I started experience two critical errors.
- Erratic EAF behavior. Previously on 1.9 it worked as Swiss watch now it all the time gives me the next error:
EAF Abnormal
Ensure current position is away from 0 and Max Step Limit so the EAF is movable
During the focus procedure, it successfully find star, after it successfully built the curve (up to star size 4-4.6) and after the curve when it starts "Finding focus point" step it fails every time with the error specified before.  Also during this error it continue to go into direction of higher step values. And there is plenty of room in any direction to move. Nothing is obstructed. As result it was ruined number of precious clear sky nights.
- I had number of GoTo / compatibility problems before using Sky Adventurer GTI, however, it did work at least one time from three. After the last firmware update GoTo practically stopped working. Actually I can move mount "manually" through AsiAir Plus virtual joystick buttons, and also if I move it to "Zero position" some times I succeed to get somewhere, but it does not move properly between two different objects, and after number of test and failures, I obtained an impression so with the new firmware it moves ONLY in South direction (even if it should move North!). And btw it moves pretty much on the same angle to the South as it should to the North! I checked location and time multiply times, tried to reset firmware but no success ;(
I wonder how I can go back to the 1.9 especially considering I'm iOS user? Or might be ZWO team can look into the issue (and other multiply issues mentioned here and everywhere) and find some solution?
