Jan75 Can't wait to re-run all tests with a guidescope.
With an RC8 type focal length, you will need to make sure there is no differential flexture, though :-).
That being said, I have been able to get consistent 0.35" type total RMS guiding with ASIAIR, albeit with a different manufacturer's strain wave gear mount, with just a 250mm focal length guide scope with flattener and ASI178MM guide camera (large, clean FOV).
That type of error should work well enough for the RC8.  I have started to tune the autoguiding to prepare for when a Mewlon 180 arrives later in the year, although most of the time, it will be used unquided (planetary).
Your 246mm should do fine.
Good luck.
