tamachi
Chetorolac
Tech@ZWO
Looking at the list of compatible Sony Cameras here - https://www.yuque.com/zwopkb/asiair/compatible-dslr-ml - and the Sony Cameras added in the latest Beta here - https://bbs.zwoastro.com/d/17089-asiair-v212-public-beta-released
The Sony A5000 is only listed as UNTESTED
And it is NOT listed in the Beta
So there is no guarantee the Sony A5000 will be able to work.
Really - the only option will be to try the settings as shown here https://www.yuque.com/zwopkb/asiair/lf7nd44fruq3vukh making sure to restart the camera and THEN connect to the ASIAIR every time you make a settings change.
You'll probably need to just try out a few settings on your own to see if you can get it to work. Again - every setting change you should restart the camera, then connect it to the ASIAIR.
