Encountering an Autorun issue. I’ve been building a darks library with Autorun. I’ve tested this issue a couple of times now. If I set main camera gain to ‘M’ for 100 (2600mm), go to Autorun and build a schedule for X number of darks at Y exposure, but set the Gain to zero (0), and then schedule another set of darks but leave the gain at ‘Default Gain’ (changed from Global Gain in this version), it appears that the previous schedule of gain0 has been inherited as the default value rather than it being constrained to just that scheduled set. So, if  I created fifty 600s subs at gain0 with first schedule, a subsequent schedule of same values but left at default gain will create a repeat of the previous set. If specify a gain value, all schedules after need to have a specific value set also. Previously, the actual gain on the camera page didn’t alter after a gain0 set and global gain remained at whatever was hard set on the camera page.
