Hello, we have carefully checked your log. Based on experience, we have the following suggestions:
1 Check whether the clutch of Mount DEC is normal
2 Check whether the rigidity of the guide scope, the guide camera, and each connecting part is normal? Is there a slight shake when under force?
3 It is recommended to set RA/DEC duration to 1000 1000 first, adjust RA/DEC Aggr to 50%, and then gradually adjust according to the guide curve after starting the guide.
