SFn8CieR If you properly shut down ASIAIR through the software, the logs will be preserved. Please upload these logs so our developers can analyze them. Additionally, for future guiding sessions, if you encounter similar issues, uploading the logs immediately will greatly help us in addressing the problem more effectively. Thank you for your cooperation!
Weird Goings on...
SFn8CieR I do wonder if this has to do with the encoders and whether its a case of the encoders are actually doing what they are meant to be doing - it's just the ASIAIR doesn't (for whatever reason) properly interpret what the encoders are doing (hence the odd guiding numbers on the ASIAIR).
Corsair
No I dont think it has to do with the encoders. I have had many successful nights guiding in the past with the same mount. This is something recent that I have noticed where the DEC goes haywire for some reason, but not all the time. Maybe its a firmware upgrade or something, dont really know.
PMTeam@ZWO
OK I will take a look when I get a chance, but most of the time I get the log but is it the same as the bug report you refer to? I have the guide logs in text form and also the phd2 graphs. Are these what you are referring to?
thanks Nick
PMTeam@ZWO
Hi, Is this the log you are referring to? Please look it over and see if you can work out why I had such weird guide graphs. Somehow I really think it is the asiair that is giving incorrect graphs and guiding figures as I cannot see any problems with the round stars in the images, yet the guiding graphs say otherwise. thanks..
Hello, we have carefully checked your log. Based on experience, we have the following suggestions:
1 Check whether the clutch of Mount DEC is normal
2 Check whether the rigidity of the guide scope, the guide camera, and each connecting part is normal? Is there a slight shake when under force?
3 It is recommended to set RA/DEC duration to 1000 1000 first, adjust RA/DEC Aggr to 50%, and then gradually adjust according to the guide curve after starting the guide.
PMTeam@ZWO
Hi, but this does not address the fact that the stars are perfectly round. I have previously checked the mechanics of the mount and guide scope and everything is very good. I really think this is an asiair issue..
thanks Nick
SFn8CieR Hi Nick, could you please send us the FITS files from the time period in question? This will help us better understand and address the problem. Thanks!
PMTeam@ZWO
When I try to upload the fits file it will not upload.
I think the file is too big, taken with a full frame camera. 46.8Mb
Is there another way to do this?
thanks Nick
SFn8CieR Hi Nick, you can send the file to the email address luffy.liu@zwoptical.com. I will forward it to the development team for analysis. Thank you.
PMTeam@ZWO
I have tried to email but the file is too big. I dont have dropbox or cloud or anything like that. Will a jpg version of the file be adequate? I tried to upload it but its too big as well.
thx Nick
Corsair
I will email it to you. It is a jpg file but you can see that the stars are round. Time of photo is 21.35 on 20240803 which matches the glitches in my phd log graph and shows that the 5 min exposure the stars are round and do not show signs of the DEC glitches. I think it is the asiair that is displaying the incorrect information. I also have noticed over many nights now that the guiding is initially quite good at around 0.6, 0.7 rms and after a while it gets worse going up to 2 rms, but when I clear the guiding graph and watch the numbers, it stays at around 0.6, 0.7 again for a while then creeps up again, and so I clear the graph again and so on. There must be a cumulative error in the aisiair for the ioptron mounts, as I have read that others are having the same issues. Please advise.
many thanks again
Nick
SFn8CieR Hi Nick, thanks for sending the JPG image. Could you let us know if this is a single frame or a stacked image? Many thanks again!
PMTeam@ZWO
This is a single exposure. cheers Nick
PMTeam@ZWO
Is there any progress here, I have no response, thanks Nick
