Prismokay The unit is getting power, and powering the output ports, but it does not boot, does not connect to the other equipment, and is no longer recognized by my computer as a connected device when I plug it in.
Give this a try...
1) Turn the ASIAIR off and remove power from it.
2) wait half a minute or so, just in case there is a large enough capacitors in there (there really isn't).
3) connect power, but with ASIAIR turned off.
5) hold down black reset button, and keep holding it down when turning on the ASIAIR power switch.
6) keep on holding the rest button for at least 5 seconds. Longer duration does not hurt.
7) release the reset button, and then power off ASIAIR again.
8) again, wait half a minute before turning ASIAIR back on. Removing power cable in between probably does not hurt, either.
9) (connect power back) and turn on ASIAIR.
Does ASIAIR boot up now? See if you can find its WiFi hotspot, etc.
If successful, it has booted with the original firmware that came from the factory when you bought it.
Connect to the iOS ASIAIR app, and it should find the ASIAIR WiFi (if not, try connecting to the ASIAIR's hotspot). The app should then ask to update the firmware to one that matches the app.
Steps 5) is often missing from instructions from the YouTube and Facebook shills.
