azskyguy I try to run WiFi at 2.4 but it keeps switching to 5ghz where I get less range.
Check your WiFi router for a setting that is usually called Band Steering. The modern routers try to move the remote devices to the 5 GHz bands if Band Steering is turned on.
You can also get a cheap router like a GLnet Opal, and use that as a repeater, and only turning on the 2.4 GHz radio on the Opal.
