Still not resolved is this nasty start screen rotating error on my ipads. First landscape (horizontal) mode with a sky object in red, then it rotates to the side with an image of the ASIAIR plus and "enter device", next scrren is your APO telescope which rotates upside down, then there is a screen to connect on of my two ASIAIRs (still upside down). an the it enters finally the "as easy as 1-2-3" screen (upside down. Then you have to hard stop the app and restart another time the whole APP with 4 screens to get it right, or you turn your whole ipad 180° around. I have never seen such an stupid start of an app. I would request to have an option to disable all the start screens and go directly in the app. Same when I change to my other ASIAIR - no questions needed.
My other recommodation would be an automatic temperature coefficient calculation. after some nights and some dozends AF procedures the EAF (with temperature sensor) should know the right focus position depending on the temperature. Should be easy to implement and would be very helpful.
My last wish is the maximum AF step size - in the moment limited to max. 200. I use a Planewave CDK17 and a Celestron RASA36 with the ZWO EAF, to adapt them to these big telescopes I built a toothed belt drive with very fine transmission for high precision. I need a AF step size of 1000 or at least 500 AF step size for a proper parabolic curve.
Claus www.possi.space
