nhmorgan Hello. Sony A7R V is on our support list. You can try it by connecting.
PMTeam@ZWO It is indeed on the supported camera list, but it doesn't work with the ASIAir Plus or Mini. The camera will connect to the ASIAir and will download images from the camera, but the ASIAir won't control the camera without a shutter release cable. It says "exposure failure." The problem is with the ASIAir software.
Hi, after upgrading the app to v2.3, my AM5 doesn't respect my AMF settings anymore. It now stops tracking and starts flipping 5 minutes before/after meridian, although I set both to 1 minute. Could you check why this happens? Thanks!
itaqmail Hello. Are you using IOS or Android? What is your AM5 firmware version?
Dear ZWO, when I ran the new 2.3 version app, it triggered a firmware update. The firmware install went to 31% and just stopped. My firmware version is showing 11.56. Is all okay?
zephirus Hi. You can perform the following steps: 1 Click on the “i” icon and use "Reset Firmware" 2 Uninstall the ASIAIR APP 3 Re-download the ASIAIR APP from the App Store, you will be reminded to update the firmware after downloading.
Hello team, In new release in Sky atlas view the mosaic button Is disabile why? I open the ticket from the app, plesse can you resolve fast these issue? Second point in bug report there are some part in china language, please correct It in english for the others users.
enzinho25 Hello. Shoot in preview mode and plate solve it. After the solve is successful, everything will be normal.
enzinho25 Hi. Regarding your first question: Shoot in preview mode and plate solve it. After the solve is successful, everything will be normal. Regarding your second question: can you provide a screenshot? Thank you.
When will we get support for different gain on guidecam depending on filter in 2600mm duo??
janekosa also a automatic procedure to measure the EAF backslash. Will be easy to implement
PMTeam@ZWO update done. For the next update I suggest this feature: the option to assign a specific gain value under AF parameters for each filters, and not only th exposure time. Now the gain is the same used to get the images, usually the optimal one (like 100 for my asi2600MC). But when you use filters will be great to perform AF procedure with a higher gain, like the max value. This will help to get better results with dim stars. Thanks
Nat74 Thanks for the suggestion, I'll feed it back to the development team for consideration
PMTeam@ZWO iOS and firmware 1.3.7. I've upgraded the AM5 mount to the newest version, lemme try again in the next few days
nhmorgan Sony will never work with Asiair, there isn't even official PC driver. Where is ZWO supposed to get the driver from?
One really useful feature would be the ability to perform tilt analysis in the app for adjustments. Since ZWO sells tilt adjuster plates, but there is currently no way to make those adjustments without connecting to a PC.
nhmorgan totally agree, a method to analyze tilt on asiair would be a HUGE help...great idea!
whereisclouds This is entirely irrelevant, the ASIAir isn't running on Windows. It's most likely using libgphoto2, which does support most Sony mirrorless cameras. With that said, using a remote shutter cable isn't the end of the world and it works just fine with that.
PMTeam@ZWO OK, many thanks! I'll try this as soon as the sky clears, and report back 🙂
I have a GEM45 mount and it used to work with the USB hub workaround until v2.3. I updated to v2.3 and now it keeps on disconnecting the mount. I tried different USB hubs, tried connecting via ASI2600. Nothing worked. It would connect for few seconds and disconnect randomly. Wouldn’t start tracking. Tried connecting directly to ASIAIR pro, nothing worked. Really frustrating!
ashutoshv Hello. What is your power supply method? Have you tried switching cables?
Hey ZWO--Been playing with the new firmware for a few days now. Wondering if there is any chance you could add the rotation information to a saved target that could even be used for someone without the new CAA. So that when a user revisits a target or mosaic, the plate solve would also help the user get back to the same frame with that rotation info. Anyhow stoked to see the CAA finally here and looking forward to buying one in the new year.
The PA circle is very small in the new ASIAIR v2.3
Samsung Galaxy Tab S6 Lite with a display resolution 2000x1200, 240DPI on Android 14
Not seen in the previous firmware version.
Old firmware version
DeepSkyOne Hi, Thanks for your feedback, I will report this to the developer and they will fix it.
