This update has caused an issue with my mount. It uses a Gemini 2 controller. I can PA with no issues. Then I try to return to home position, but it does not move the mount. A window pops up that says the mount has, successfully, moved to home position within 3 to 5 seconds. When I try to use the  goto function, a window pops up and says the mount is moving to the designated target and then says it has successfully moved to the target within 3 to 5 seconds, and the target has been
centered. But again the mount has not moved at all. I can manually control the mount with no issues. Everything worked
fine before this forced update. Any ideas?
