Greetings,
I can't seem to get the ASIAIR to talk to my CEM60. I used an FTDI USB to serial cable and connected it to the D9 to phone jack cable that came with the CEM60 and tried in both the RS232 and handset ports - no luck. The baud rate is set to 9600 per the ASIAIR instructions, though I tried the faster rates with the same results.
Thinking that there may be an issue with the cable pinouts (both cables had the male connection screws) I bought a null modem adapter as a crossover but that too failed.
Does anybody know what I am missing here?
Thanks
Tom
